[GRASS5] [bug #1173] (grass) v.digit Why
this bug's URL: http://intevation.de/rt/webrt?serial_num=1173
Subject: v.digit Why
Platform: HP/UX
grass obtained from: Trento Italy site
GRASS Version: 5.0.0pre5
Again, really not a bug, but a small annoyance: Why does v.digit ask "Shall we continue?" As I have choosen to start v.digit, select a digitizer and a map and have filled in the form with information on the map, it should be quite obious that I want to continue... Anyhow, if I have changed my mind, the prompt would just be a 'Q' away...
Morten
Platform: HP/UX
Morten
Yes, v.digit expects for each action, that user does not want
to do, what he wants to do. Should be reversed, but first we need
your previous wish "undo".
There is no problem with wishes and ideas, problem is that nobody
wants to write the code.
Radim
