[GRASS5] [bug #1197] (grass) [GRASSLIST:4072] v.digit problem: unlabeled lines invisible
this bug's URL: http://intevation.de/rt/webrt?serial_num=1197
When I use v.digit to delete internal boundary lines in patched vector
files, I have a problem in the Window menu. It will not display unlabeled
lines with the "U" command. It shows the set of labeled lines correctly but
when I try to show unlabeled lines (which should be the inverse set) it
shows nothing. I tried changing the background color but it did not help.
Any ideas?
Thanks.
--- Headers Follow ---
From neteler@itc.it Mon Jul 22 16:33:01 2002
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 4F4B613965
  for <grass-bugs@lists.intevation.de>; Mon, 22 Jul 2002 16:33:01 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
  by mail.intevation.de (Postfix) with ESMTP id 198A61B6D6
  for <grass-bugs@intevation.de>; Mon, 22 Jul 2002 16:33:00 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g6MEWxn08133
  for <grass-bugs@intevation.de>; Mon, 22 Jul 2002 16:32:59 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
  by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g6MEWs924502
  for <grass-bugs@intevation.de>; Mon, 22 Jul 2002 16:32:54 +0200
Received: (from neteler@localhost)
  by thuille.itc.it. (8.11.6/8.11.2) id g6MEWra04222
  for grass-bugs@intevation.de; Mon, 22 Jul 2002 16:32:53 +0200
Resent-Message-Id: <200207221432.g6MEWra04222@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
  by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g6EKJCa00779;
  Sun, 14 Jul 2002 22:19:12 +0200
Received: from ccis01.baylor.edu (ccis01.baylor.edu [129.62.1.18])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g6EKJAn09531;
  Sun, 14 Jul 2002 22:19:10 +0200 (MET DST)
Received: from localhost (localhost [127.0.0.1])
  by ccis01.baylor.edu (8.9.1/8.9.1) with SMTP id PAA1285953;
  Sun, 14 Jul 2002 15:17:36 -0500 (CDT)
Received: from FS-EXCHANGE1.baylor.edu (flopsy.baylor.edu [129.62.3.249])
  by ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id PAA1270106
  for <GRASSLIST@listproc.baylor.edu>; Sun, 14 Jul 2002 15:11:49 -0500 (CDT)
Received: from waylon.baylor.edu ([129.62.3.228]) by FS-EXCHANGE1.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
   Sun, 14 Jul 2002 15:09:29 -0500
Received: from willie.baylor.edu ([129.62.3.227]) by waylon.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Received: from rwcrmhc51.attbi.com ([204.127.198.38])
by willie.baylor.edu (NAVGW 2.5.1.13) with SMTP id M2002071415092928526
for <grasslist@baylor.edu>; Sun, 14 Jul 2002 15:09:29 -0500
Received: from deena ([12.228.148.124]) by rwcrmhc51.attbi.com
          (InterMail vM.4.01.03.27 201-229-121-127-20010626) with SMTP
          id <20020714201148.DCHH24728.rwcrmhc51.attbi.com@deena>
          for <grasslist@baylor.edu>; Sun, 14 Jul 2002 20:11:48 +0000
Message-ID: <009d01c22b71$71d24660$6300a8c0@heg>
To: <grasslist@baylor.edu>
References: <002a01c1e489$0fe98820$6300a8c0@heg>
Subject: [GRASSLIST:4072] v.digit problem: unlabeled lines invisible
Date: Sun, 14 Jul 2002 13:02:55 -0700
MIME-Version: 1.0
Content-Type: text/plain;
  charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 5.50.4807.1700
X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4807.1700
X-OriginalArrivalTime: 14 Jul 2002 20:09:29.0622 (UTC) FILETIME=[5C658B60:01C22B72]
Sender: owner-GRASSLIST@baylor.edu
X-Listprocessor-Version: 8.2.10/991025/16:55 -- ListProc(tm) by CREN
Resent-From: neteler@itc.it
Resent-Date: Mon, 22 Jul 2002 16:32:53 +0200
Resent-To: grass-bugs@intevation.de
X-Spam-Status: No, hits=1.6 required=5.0 tests=FROM_ENDS_IN_NUMS,NO_REAL_NAME version=2.20
X-Spam-Level: *
