this bug's URL: http://intevation.de/rt/webrt?serial_num=1201
Subject: can't remove base map from reclassed map
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: grass50_exp_2002_07_12 CVS Snapshot [HEAD]
I reclassified a vector map and cannot delete its base map. The message is:
g.remove vect=buek3314.id.botyp5
[buek3314.id.botyp5@dassau] is a base map. Remove reclassed map first:
tmp.recl@dassau
There is no tmp.recl map anywhere on my pc and I never created such a map, so I guess it was some temporary file built somewhere during reclassification.
The same happened with the converted raster map:
g.remove rast=buek3314.id.botyp5
tmp.recl@dassau
I imported the map buek3314.id.botyp with v.in.shape, converted it into raster
format and reclassified each format. Later I could delete all maps except these 2. Did I miss something ?
thanks
Otto Dassau
