this bug's URL: http://intevation.de/rt/webrt?serial_num=1210
Subject: quering r.cross result crashes
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: grass50_exp_2002_07_12 CVS Snapshot [HEAD]
I converted 2 maps (covering exactly the same area) from vector into raster format. Due to projection (Gauss-Krueger) there are small "No Data" areas around the converted raster maps then -> I can query them - no problem.
When I use r.cross, these "No Data" areas in the resulting map
cause "segmentation fault" when I try to query the result map with d.what.rast or r.stats ...
When I zoom in (exclude these "No Data" areas from query) everything is fine.
regards
Otto Dassau
