this bug's URL: http://intevation.de/rt/webrt?serial_num=1228
Subject: Floats for XY regions!
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 5pre4
after defining a region like
N:1 S:-1 W:-1.75 E:0.25 NSRES&EWRES:0.1
in a XY location, another run of "g.region",option=1 will most likely result in a display of
N:1,S:-1,W:2,E:0, NSRES&EWRES: illegal distance
even WITHOUT changing the above mentioned parameters.
A possible solution would be to make the regions dimension FLOATS insteads of INTs.
Peter
[Why the funny numbers? -> GRASS can *even* be used to calculate Mandelbrot sets]
insteads of INTs.
Mea Culpa.
The region's dimensions *are* floats. However, the interactive region
editing code rounds them to a whole number of seconds for lat-lon
locations, and to a whole number of units for everything else.
This was done originally to prevent the value from exceeding the width
of the editing field and messing up the display. I'll look into
producing a fix (or, at least, a workaround) for X-Y locations.
In the meantime, using g.region non-interactively should work.
