this bug's URL: http://intevation.de/rt/webrt?serial_num=1238
Subject: r.transect_no_result
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.0pre4
Please enter error description here (and your name)
I did not get any results with r.transect.
Could you please change in source code main.c
line 85 and 86 from:
sprintf (command, "r.profile map='%s' width=%s result=%s
line=",
parms.map->answer, parms.width->answer,
parms.result->answer);
to updated command of r.profile for example:
sprintf (command, "r.profile input='%s' output=-
profile=",
parms.map->answer);
Then it'll be fixed.
ciao
Hans Fuchs
line=",
profile=",
parms.map->answer);
Thanks for the hint!
I think also profile= must be eliminated and also the
width parameter in r.transect (and the html file updated and
tcltkgrass for r.transect).
This should reach the release_branch, otherwise r.transect
is unusable.
