this bug's URL: http://intevation.de/rt/webrt?serial_num=1325
Subject: cant start grass5, seems some lib not compatible
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.0
after install, i type grass5
then it shows me:
etc/lock: lib/libc.so.6 version "glibc_2.1.3" not find (required by ...)
root is currently running grass5. concurrent use is not allowed.
and then seems the process is over, return me to command status. And i can't see any prompt about location or mapset.
what's the matter?
then it shows me:
what's the matter?
It appears that the precompiled binaries aren't compatible with your
particular Linux distribution.
