[GRASS5] [bug #1361] (grass) s.in.ascii man page says site file delimiter is user controlled
this bug's URL: http://intevation.de/rt/webrt?serial_num=1361
Subject: s.in.ascii man page says site file delimiter is user controlled
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: GRASS 5.0.0pre1 (May 2001)
the s.in.ascii man page says
GRASS 5.0 internal sites format in sites_list/
       If the user wants to directly generate site files, the
       following information can be used:
       Each line of the ascii input file should contain either
       two or three coordinates (x,y and optionally z) separated
       by a user-selectable field-delimiting character. After
       the coordinates there are optional attribute fields sepa
       rated from the coordinates and from each other with the
       same user-selectable field delimiter.
****Is it really "user-selectable"?
Not according to man sites.format.
It is a "|" [which makes things tough for big5 chinese]
