this bug's URL: http://intevation.de/rt/webrt?serial_num=1367
Subject: d.mon manpage doesn't say how to get bigger monitors
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 5.0pre1
the user should have a hint about where to learn how to make different sized monitors
right therer on the d.mon manpage.
Also man/man1/monitorcap.1
should be in a different section than(1), because 1 is for commands.
maybe 5. then you can write SEE ALSO monitorcap(5)
