[GRASS5] [bug #1407] (grass) don't ignore C-z suspend in many forms
this bug's URL: http://intevation.de/rt/webrt?serial_num=1407
Subject: don't ignore C-z suspend in many forms
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 5.0pre1
many grass programs ignore C-z, the suspend char, for no good reason, during,
e.g. a form filling out session. Yes, some of us might still prefer to
use the C-z to do some quick shell commands [with the grass envronment] rather than
start another window with their window manager.
At least d.3d ignores C-z.
All programs which use the vask library will behave this way, as
V_init() calls raw(), which causes the signalling codes (Ctrl-C,
Ctrl-Z etc) to be passed through to the application rather than
generating signals.
There are four plausible approaches:
1. Leave as is.
2. Don't call raw(); Ctrl-C will then (typically) generate SIGINT,
which would need to be caught. Ctrl-Z will (typically) generate
SIGTSTP, which will suspend the program; however, it is necessary to
suspend curses first (so that the terminal is usable), and resume
curses and refresh the screen upon resumption (SIGCONT). I say
"typically", because the exact codes which generate the signals can be
user configured, e.g. via stty.
3. Call raw(), but have the application explicitly handle code 26
(Ctrl-Z), similar to the handling of code 3 (Ctrl-C).
4. Similar to the previous option, but use tcgetattr(), gtty() or
ioctl(TCGETA) to read the terminal configuration rather than assuming
Ctrl-C -> SIGINT, Ctrl-Z -> SIGTSTP etc.
