this bug's URL: http://intevation.de/rt/webrt?serial_num=1442
Subject: NVIZ Whiteout
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.0.0
I have a georeferenced Aster-DEM and Spot-Data in a LL-Location.
Displaying each of them individually within NVIZ works fine.
Alas, draping the Spot imagery over the DEM fails in a strange way:
The Spot-datas color table was set to WAVE to ensure a bright and colorful
result, while DEM was set to a rather dull GREY.EQ table.
Applying the Spot data as "color" for the DEM renders a purely white
landscape.
The mentioned spot scene is definetely not a sibirian 'winter wonderland' or
a frozen lake, there should be quite a bit of data appearing on screen.
Both data sets are well behaved: r.info shows ranges of 73-250 (DEM) and
1-14 (Spot), no NULLs.
I already probed for a possible scaling problem:
The DEMs resolution is 0:00:00.9 while the Spot imagery is about 0:00:00.3
Setting the g.region to the lower of the two values didn't affect the
white-out phenomena at all.
Any help/advice would be much appreciated
Peter
