Eric has submitted the C changes.
I have submitted the tcltkgrass changes, thanks.
It's true (but wanted?) that -l doesn't work in tcltkgrass.
Reason is
if(isatty(0)) /* check if on command line */
(line 217).
Should we remove that if condition?
Reason is
(line 217).
Yes.
> Reason is
> (line 217).
Yes.
Done.
PS: Have also extended #25 in SUBMITTING as suggested.
