[GRASS5] [bug #1498] (grass) v.build doesn't write right coor_size attribute for PostGrass
this bug's URL: http://intevation.de/rt/webrt?serial_num=1498
Subject: v.build doesn't write right coor_size attribute for PostGrass
Platform: WindowsNT/2000/XP
grass obtained from: Trento Italy site
GRASS Version: grass51_exp_2002_12_27
I'am testing postgis support for grass and
after i created a new postgis vector "file" and i run v.build to build topology.
Then i started d.vect and i get message:"Size of 'coor' file differs from value saved in topo file." in vect_open_topo function
It looks like vect_save_topo gets wrong values of coor_size and writes it to topo file
Tomek C.
topology. Then i started d.vect and i get message:"Size of 'coor' file
differs from value saved in topo file." in vect_open_topo function It looks
file Tomek C.
Fixed. Radim
