this bug's URL: http://intevation.de/rt/webrt?serial_num=1507
Subject:
I have GRASS 5.0.0pre2 installed.
I installed the new X11 in OSX 10.2.3 and nothing works anymore.
I typed grass5 and this is the response:
Starting GRASS ...
: command not foundtc/Init.sh:
ERROR: Invalid return code from gis_set.tcl.
Please advise GRASS developers of this error.
/usr/local/grass5/etc/Init.sh: LOCATION_NAME: parameter null or not set
PS the invalid code return shoud be 127
If I type grass5 + location/mapset I have a correct response, but if I then type: g.help
I have:
Error opening terminal: vt100
il I type: tcltkgrass&
I have:
GRASS 5.0.0pre2 > Error in startup script: couldn't execute "xwininfo": no such file or directory
while executing
"exec xwininfo -id [winfo id .w_g] | grep -i Corners"
invoked from within
"scan [exec xwininfo -id [winfo id .w_g] | grep -i Corners] {%*s %d%d} dx dy"
(file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1887)
invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
(file "/usr/local/grass5/bin/tcltkgrass" line 17)
and wish shell opens and closes immediatly.
I think there's something wrong with the new graphic interface.
