this bug's URL: http://intevation.de/rt/webrt?serial_num=1565
Subject: man pages are ugly if terminal window is small
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 5.0.0
The man pages are ugly if the terminal window is smaller than 87 columns wide.
It doesn't wrap cleanly; normal system man pages usually display "Reformatting foo(1), please wait..." and then look good in a smaller window. The grass pages display "Reformatting r.transect(1), please wait..." and then mess up the indentation/word wrap on the next line.
e.g.:
DESCRIPTION
This progream outputs, in ASCII, the values in a raster
map which lie
along one or more user-defined transect lines. The
transects are
described by their starting coordinates, azimuth, and
distance. The
transects may be single-cell wide lines, or multiple-cell
wide lines.
The output, for each transect, may be the values at each
of the cells,
or a single aggregate value (e.g., average or median val-
ue).
g.html2man CR/LF vs <P> issue ?
This is on 5.0.0, multiple linux platforms. I don't know if it is fixed in 5.0.1 or CVS.
Hamish
columns wide.
87? That suggests a problem with your "man" program, or at least with
the way in which it is being invoked. Are you running the "make"
command in a wider than normal terminal?
next line.
GRASS installs pre-formatted man pages by default. I suggest changing
the default target in html/Gmakefile from:
all: htmlpages g.help-manpages
to:
all: htmlpages manpages
This should install the nroff source, which will be formatted
dynamically.
On Mon, 3 Feb 2003 04:50:31 +0000
> columns wide.
87. This happens to me on both RedHat 7.3 & Debian/Sarge, BUT...
Are you running the "make" command in a wider than normal terminal?
Most probably yes.
I just tried it on the laptop (RH8.0), it doesn't wrap nicely either, but on that machine the magic number is <66 columns wide, which doesn't happen much.. I can guess that the terminal window was smaller on compile due to the smaller screen, but couldn't remember. I'll have a go at putting 5.0.1 on that and see what happens.
to:
dynamically.
I'll give it a shot as well.
Hamish
