this bug's URL: http://intevation.de/rt/webrt?serial_num=1582
Subject: Tcl/tk menu: Display dimentions doesn't work
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 5.0.0
This is broken in 5.0.0, and the code snippet below is from CVS..
I don't know what xdriver_defaults(width) calls or if it has been fixed in CVS wherever that call goes to.
Config -> Options -> Display Dimensions:
XDriver default HEIGHT and XDriver default WIDTH options don't work.
in src/tcltkgrass/main/gui.tcl:
label $path.label1 -anchor w -text "XDriver default LEFT position"
entry $path.entry1 -textvariable xdriver_defaults(left)
label $path.label2 -anchor w -text "XDriver default TOP position"
entry $path.entry2 -textvariable xdriver_defaults(top)
label $path.label3 -anchor w -text "XDriver default WIDTH"
entry $path.entry3 -textvariable xdriver_defaults(width)
label $path.label4 -anchor w -text "XDriver default HEIGHT"
entry $path.entry4 -textvariable xdriver_defaults(height)
label $path.label5 -anchor w -text "CELL driver WIDTH"
entry $path.entry5 -textvariable env(GRASS_WIDTH)
label $path.label6 -anchor w -text "CELL driver HEIGHT"
entry $path.entry6 -textvariable env(GRASS_HEIGHT)
do they need to be updated to GRASS_WIDTH and GRASS_HEIGHT ?
Hamish
