this bug's URL: http://intevation.de/rt/webrt?serial_num=1784
Subject: grass_r_interface.html corrections
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 5.0.0+
I found the following problems in grass_r_interface.html ... have fun
Hamish
--- grass_r_interface.html.OLD Mon Apr 7 18:40:13 2003
+++ grass_r_interface.html Mon Apr 7 20:05:23 2003
@@ -209,7 +209,8 @@
map!
<p>After loading a map, first we can test if any NA raster cells are present
-in the map (example: slope map):
+in the map (example: slope map <a href="#genSlope">from below</a>):<BR>
<div class="code"><pre>
slope <- rast.get(G, rlist="slope")
summary(slope$slope)
@@ -242,15 +243,15 @@
"landcov" map from GRASS:
landcov <- rast.get(G, rlist="landcov")
-landcov.nas<-which(is.na(landcov$landcov))
-mylandcov<-landcov.nas[!is.na(landcov$landcov)]
+landcov.nas <- which(is.na(landcov$landcov))
+mylandcov <- landcov$landcov[!is.na(landcov$landcov)]
summary(myslope)
-summary(mylanduse)
+summary(mylandcov)
</div></pre>
-Now further statistical analysis could be done.
-<p>Storing back the NAs is a three step procedure:<br>
-1. Create new empty numeric vector:
+Now further statistical analysis can be done.
+<p>Restoring the NAs is a three step procedure:<br>
+1. Create a new empty numeric vector:
new.myslope <- numeric(length(slope$slope))
</div></pre>
@@ -272,7 +273,7 @@
plot(G, slope$slope)
</div></pre>
-A mathematical is is a simple subtraction:
+A mathematical check is a simple subtraction:
summary(slope$slope - new.myslope)
</div></pre>
@@ -280,13 +281,12 @@
The result should be "0" for Min, Median and Max.
<p>Dealing with legends
-<p>Drawing a legend needs some work: Generate levels,
-analyse topo range for useful breaks:
+<p>Drawing a legend requires some work:<BR>
+Generate levels, analyse topo range for useful breaks:
library(MASS)
truehist(leics$topo, nbins=100)
-legendlevels <- as.ordered(cut(leics$topo, breaks=c(50,100,150,
-200, 250)))
+legendlevels <- as.ordered(cut(leics$topo, breaks=c(50,100,150,200, 250)))
plot(G, leics$topo, col=terrain.colors(20))
legend(x=c(452000,456000), y=c(316000,320000), pch=c(1:5),
legend=levels(as.ordered(legendlevels)))
@@ -298,8 +298,8 @@
gc()
</div></pre>
<p>----------------------------<br>
-Another example with "leics" (the system() function
-allows to call external commands):
+Another example with "leics" (the <tt>system()</tt> function
+allows calls to external commands):
system("g.list rast")
</div></pre>
@@ -309,6 +309,7 @@
print(list.GRASS(type="rast"))
</div></pre>
+<a name="genSlope">
Calculate slope/aspect directly in GRASS:
system("r.slope.aspect el=topo as=aspect sl=slope")
