[GRASS5] [bug #1784] (grass) grass_r_interface.html corrections
If it is a clear bug you can fix it in the CVS directly.
Where? I couldn't find it.
web/statsgrass/ only has index.html and grass_r_insthints.html as far as I can
tell.
shrug,
Hamish
tell.
So that is the real question. :slight_smile:
Markus probably will answer that soon.
> tell.
The files I copy manually into the web space to keep the
web CVS directory small. Probably I should move the entire
"tutorial" onto mpa.itc.it instead of grass.itc.it?
