this bug's URL: http://intevation.de/rt/webrt?serial_num=1810
Subject: v.digit module, nviz
Platform: other
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.02
Hallo I am Ingo Dickel
from Munich (Germany),
i have self compiled the version 5.02 of Grass.
My Linux System is Suse Linux 8.2. My hope was that i can start nviz
with the new support for tcl/tk 8.4. But there was no way.
The error lines from Nviz Version: @(#) 5.0.2 (April 2003)was:
**toplevel made
**child killed: segmentation violation
** while executing
**"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f **/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=grund -name NVIZ **>&@stdout"
** ("eval" body line 1)
** invoked from within
**"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f **$env(GISBASE)/etc/nviz2.2/scri pts/nviz2.2_script $argv -name **NVIZ >&@stdout"
**"if {$argv == ""} {
**#no arguments
**eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f **$env(GISBASE)/etc/nviz2.2/scrip ts/nviz2.2_script -name NVIZ **>&@stdo..."
** (file "/usr/local/grass5/bin/nviz" line 16)
Later i try to test v.digit
| GRASS-DIGIT Modified 4.10 Main menu |
| MAP INFORMATION | AMOUNT DIGITIZED |
| Name: Convex hull map | # Lines: 0 |
| Scale: 2400 | # Area edges: 1 |
| Person: | # Sites: 0 |
| Dig. Thresh.: 0.0300 in. | - - - - - - - - - - - - - -|
| Map Thresh.: 1.8288 meters | Total points: 24 |
| OPTIONS: | |
| Digitizer: Disabled | |
| Digitize Edit Label Customize Toolbox Window Help Zoom Quit * ! ^|
|GLOBAL MENU: Press first letter of desired command. [Upper Case Only] |
but in this dialog above is no key going.
So i was a little bit frustrated. It was enogh to do become the compile
running. Maybe i have make an mistake.
I load the newest binarys on my Computer and install it.
But i have the exact same problems.
I think about to change the distrubition of my Linux System,
but maybe you can help me.
Thank's so lot !
IWDickel@genion.de
