[GRASS5] [bug #1827] (grass) cannot open shared file (using grass5 that was O.K.)
this bug's URL: http://intevation.de/rt/webrt?serial_num=1827
Subject: cannot open shared file (using grass5 that was O.K.)
Platform: other
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
Please enter error description here (and your name):
Tis is followup to my previous "bug report":
Grass5.1 started
but shows an error that I do not understand
Jonas Mockus
GRASS 5.1.0-cvs:~/grass5.1 > d.m &
[1] 19644
GRASS 5.1.0-cvs:~/grass5.1 > Error in startup script: ps.map: error while loading shared libraries: libpq.so.2: cannot open shared object file: No such file or directory
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 8)
Cleaning up temporary files.....
done
Request Tracker wrote:
Grass5.1 started
[1] 19644
libpq is the PostgreSQL client library; it has to be present in order
to use GRASS 5.1.
