[GRASS5] [bug #1923] (grass) Compilation error of
this bug's URL: http://intevation.de/rt/webrt?serial_num=1923
Subject: Compilation error of
Platform: GNU/Linux/i386
grass obtained from: CVS
My name is jonathan Ghellere and that error occurs:
make[2]: Entrando no diretório `/root/Grass5/grass51_exp_2003_05_31/lib/gis'
gcc -g -O2 -Wall -I/root/Grass5/grass51_exp_2003_05_31/include -I/root/Grass5/grass51_exp_2003_05_31/dist.i686-pc-linux-gnu/include -I/root/Grass5/grass51_exp_2003_05_31/include -I/root/Grass5/grass51_exp_2003_05_31/dist.i686-pc-linux-gnu/include \
        -o OBJ.i686-pc-linux-gnu/get_datum_name.o -c get_datum_name.c
get_datum_name.c:33: conflicting types for `G_ask_datum_name'
/root/Grass5/grass51_exp_2003_05_31/include/gisdefs.h:533: previous declaration
of `G_ask_datum_name'
/root/Grass5/grass51_exp_2003_05_31/include/gis.h:36: warning: `GRASS_copyright' defined but not used
make[2]: ** [OBJ.i686-pc-linux-gnu/get_datum_name.o] Erro 1
make[2]: Saindo do diretório `/root/Grass5/grass51_exp_2003_05_31/lib/gis'
make[1]: ** [subdirs] Erro 1
make[1]: Saindo do diretório `/root/Grass5/grass51_exp_2003_05_31/lib'
make: ** [default] Erro 1
You need to use the CVS HEAD of GRASS 5.0, or at least the 5.0 snapshot
with the same date as (or as close as possible to) the 5.1 snapshot
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
