this bug's URL: http://intevation.de/rt/webrt?serial_num=2003
Subject: Integrated IHO S-57 Standard
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0 as of 10Apr03
Nick Neely:
My suggested GRASS improvement is inclusion of read/write capability of International Hydrographic Institute (IHO) S-57 standard for Electronic Nautical Charts (ENC). In the U.S., and elsewhere I presume, it is possible to download comprehensive databases of waterway data (free of charge) that would satisfy a huge segment of maritime GIS data needs. ArcView has an ENC reader and I think that to keep GRASS fairly competitive as an alternative to expensive commercial software, S-57 should be an integrated read/write format. Some open source work has been done on this already (http://gdal.velocet.ca/projects/s57/index.html) so the GRASS development team wouldn't be doing everything themselves.
Thanks for your time.
Nick Neely:
v.in.ogr in 5.1. Direct support for reading (without conversion)
for OGR is under construction.
Radim
Nick Neely:
v.in.ogr in GRASS 5.1 should be able to read it. Tried with:
http://www.digitalocean.ca/DigitalOcean%20E-Store/Sample_data/s57.zip
Note that I have applied a small fix right now, so only the
current CVS contains the fix (grab from there). The end-of-the-week
CVS source code snapshot as well as the precompiled binaries will
be created next Saturday morning.
