[GRASS5] [bug #2150] (grass) PG.IN.DBF - import error
this bug's URL: http://intevation.de/rt/webrt?serial_num=2150
Subject: PG.IN.DBF - import error
Platform: other
grass obtained from: Other (CDROM etc)
in module pg.in.dbf there is a BIG error.
When it import dbf files it creates pgsql table in current db. It creates field similar DBF structure
but there is a BIG error in floating numbers. If there is a value with decimal point the module
pg.in.dbf always create REAL field. THIS IS AN ERROR ! Real field is limited to 6 number including
fractions: the numbers are broken. IT must creates NUMERIC field, the only exact field for
decimal precision. Please correct this one !!
I will fix this one with the others.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Thierry Laronde (Alceste) <tlaronde@polynum.org>
Key fingerprint = 0FF7 E906 FBAF FE95 FD89 250D 52B1 AE95 6006 F40C
