[GRASS5] [bug #2152] (grass) VRML 1.0 export
this bug's URL: http://intevation.de/rt/webrt?serial_num=2152
Subject: VRML 1.0 export
Platform: other (dual-G4 / MacOSX 2)
grass obtained from: Other (CDROM etc) (OpenOSX)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.2
The VRML 1.0 export is not working well. The mesh producted is not standard VRML. It
adds a ' , ' after the last Coordinate3 point description. Same for the last
IndexedFaceSet : should be "a,b,c,-1" and not "a,b,c,-1,"
Yann
The attached patch to p.vrml would fix this (presumably the Material Color
section should have the same treatment). But I haven't had any problems
with the current output. Are there some readers the VRML output won't work
with? Can you give a link to somewhere describing the VRML standard that
shows it as you describe? Then we could apply the change to p.vrml
(attachments)
put_grid.c.diff (1.48 KB)
shows it as you describe? Then we could apply the change to p.vrmlIndex: put_grid.c
The VRML 1.0 standard explicitly permits a trailing comma:
http://www.web3d.org/technicalinfo/specifications/VRML1.0/index.html#Fields
  Multiple-valued fields are written as a series of values
  separated by commas, all enclosed in square brackets. If the
  field has zero values then only the square brackets ("") are
  written. THE LAST MAY OPTIONALLY BE FOLLOWED BY A COMMA. If
  the field has exactly one value, the brackets may be omitted
  and just the value written. For example, all of the following
  are valid for a multiple-valued field containing the single
  integer value 1:
[Emphasis mine.]
So, it's a bug in the viewer.
FWIW, VRML 97 is even more liberal; the comma is considered a
whitespace character.
