[GRASS5] [bug #2178] (grass) r.bilinear writes 0 instead of NULL
this bug's URL: http://intevation.de/rt/webrt?serial_num=2178
Subject: r.bilinear writes 0 instead of NULL
grass obtained from: CVS
BUG
r.bilinear write 0 instead of NULL:
GRASS:~ > r.info -r elev.bilin
min=0.000000
max=1432.306152
GRASS:~ > r.null elev.bilin setnull=0
Writing new data for [elev.bilin]... 100%
min=1136.674438
max=1432.306152
This happens at the west/north result map borders where 0 instead of NULL
is written.
BUG
min=0.000000
max=1432.306152
min=1136.674438
max=1432.306152
is written.
It should only be East/West. The North/South check writes NULLs.
I've committed a fix; this should probably go into 5.0.3.
