this bug's URL: http://intevation.de/rt/webrt?serial_num=2253
Subject: G3d_writeWindow() uses variable with no value
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.0.3
The function G3d_writeWindow() (in g3dwindowio.c) uses the variable path before
it is given a value. The calls to G3d_getWindowLocation() and G3d_createPath()
(on lines 255 and 256) should probably be moved above the if statement starting
on line 241 so that path has a value for the call to sprintf() on line 249
