[GRASS5] [bug #2255] (grass) Problem exporting site map as DXF file
this bug's URL: http://intevation.de/rt/webrt?serial_num=2255
Subject: Problem exporting site map as DXF file
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.0.3
Hi, my name is Stefano.
I have a site map with 40 points and i would export them as dxf file of points with Grass
5.0.3 under SuSE 8.2. With the sequence of commands: sitemap -> s.to.vect -> vector point
map -> v.out.ascii -> ASCII vector point map -> v.out.dxf -> output dxf file, i obtain a dxf file
with 4 layers "formally" correct, in the sense that a CAD program such Qcad open them
without error messages, but, as you can see below, the file do not contain any information
about the coordinates of points and so any graphic point is displayed. BTW, I have no
problems exporting in dxf vector maps of lines and polygons.
Can you give me some hints?
Thanks in advance!
Stefano Perona
0
SECTION
  2
HEADER
  9
$LIMMIN
10
404000.000000
20
5031000.000000
  9
$LIMMAX
10
409000.000000
20
5035000.000000
  0
ENDSEC
  0
SECTION
  2
TABLES
  0
TABLE
  2
LTYPE
70
     1
  0
LTYPE
  2
CONTINUOUS
70
    64
  3
Solid line
72
    65
73
     0
40
0.0
  0
ENDTAB
  0
TABLE
  2
LAYER
70
     5
  0
LAYER
  2
0
70
     0
62
     7
  6
CONTINUOUS
  0
LAYER
  2
AV_POZ_N_VECT@STEFANO
70
    64
62
     1
  6
CONTINUOUS
  0
LAYER
  2
LV_POZ_N_VECT@STEFANO
70
    64
62
     2
  6
CONTINUOUS
  0
LAYER
  2
LC_POZ_N_VECT@STEFANO
70
    64
62
     3
  6
CONTINUOUS
  0
LAYER
  2
AC_POZ_N_VECT@STEFANO
70
    64
62
     4
  6
CONTINUOUS
  0
ENDTAB
  0
ENDSEC
  0
SECTION
  2
ENTITIES
  0
ENDSEC
  0
EOF
