It must be '.' instead of ',' (we speak US here):
Eg
158135.000000 175101.000000 ...
Change it with a text editor.
Eg
guest user via RT wrote:
Tyring to access (d.sites, s.out.ascii) a sites file with the
following format:name|specprod8601
labels|east north Rcode varint varfloat comcod
158135,000000|175101,000000|#1 %116,198 %7,000 %23094
105265,000000|196713,000000|#2 %97,6064 %1,000 %44021
173626,000000|175036,000000|#3 %84,3267 %1,000 %24062
154166,000000|179702,000000|#4 %83,4805 %4,000 %23088
148799,000000|172180,000000|#5 %82,8372 %1,000 %21004
155340,000000|177049,000000|#6 %75,8749 %17,000 %23047
154556,000000|170726,000000|#7 %74,3438 %2,000 %21018
etc...531 sitesI get the follwing error:
ERROR: ebuf 158135,000000 nbuf 175101,000000
Eg
158135.000000 175101.000000 ...Change it with a text editor.
Out of curiousity, how was that sites file generated? I'm fairly sure
that it wasn't with any standard GRASS module, but it might be some
obscure contrib module, or an add-on for which we might get queries
(in the same way that these lists often get queries regarding
GRASSlinks etc).
Eg
GRASSlinks etc).
No, it was certainly generated with a home made script. I often use R to
create data and colored circles or triangles that I then map out with
ps.map. For that I copy files directly into the sites directory (I guess I
should better use s.in.ascii...)
I don't know why I didn't notice this problem before, however...maybe I
never used this specific site file.
Moritz
