[GRASS5] [bug #2324] (grass) NVIZ: child process: segmentation violation located
this bug's URL: http://intevation.de/rt/webrt?serial_num=2324
Subject: NVIZ: child process: segmentation violation located
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: 5.3 CVS and 5.0.3
To whom it may concern:
I have narrowed down the source of the NVIZ segfault error. The error has appeared for me using both 5.0.3 and version 5.3 I picked up from CVS today in hopes this would be resolved.
The error has occured with a message like this, and can be generated even with no data using the command:
nviz -q
child killed: segmentation violation
    while executing
"exec /usr/local/grass53/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass53/etc/nviz2.2/scripts/nviz2.2_script -q -name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/usr/local/grass53/bin/nviz" line 16)
The offending segmentation fault happens on this line of etc/nviz2.2/scripts/nviz2.2_script:
    togl $BASE.canvas -rgba true -double true -depth true
Which appears to be creating some sort of gl object as a canvas element.
I thought that the problem might be in my OpenGL implementation. I am using Debian (testing). I got the error when using the xlibmesa3-glu and xlibmesa4-gl packages. I switched to the mesag3 package (the development package is mesag-dev) and NVIZ now works correctly.
The short and skinny is:
NVIZ works correctly (this bug does not exist) with Mesa-3.
NVIZ does not work with xlibmesa.
And a slightly related question: is there a new monitor implementation in the works for 5.7 with scrollbars, zoom buttons, etc? Is building one in tcl/tk appropriate? It appears that NVIZ uses a similar mechanism ...
Yep. "Togl" is an OpenGL canvas widget for Tcl/Tk.
Odd. It's quite unusual for crashes to be related to the use of
OpenGL. However, there are a few common linking problems,
specifically:
1. If libGL uses pthreads, it sometimes helps to explicitly pass the
-lpthread switch when linking the application.
2. SGI's libGLU is written in C++, which is never a good thing for
binary compatibility. Mesa's libGLU (which is now considered obsolete
due to the lack of the GLU 1.2 tesselator API) is written in C.
What you are describing isn't a monitor but a GUI. Note that monitors
aren't restricted to just XDRIVER, but also include the PNG and CELL
drivers; GUI components wouldn't be meaningful for those drivers.
On the GUI front, there is already d.dm/d.m (which are part of GRASS),
and also Radim's QGIS (which is separate).
Is building
mechanism ...
Tcl/Tk has the advantage of portability, but Tcl isn't a particularly
nice language for writing substantial applications, and Tk is fairly
limited compared to other GUI toolkits.
