this bug's URL: http://intevation.de/rt/webrt?serial_num=2326
Subject: Missing row and column when importing raster map with r.in.gdal
Platform: other
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.2 (April 2003)
I tried to import a raster grid with r.in.gdal, and apparently, a row and a column is missing in the
imported raster map (see below).
# Files and directories:
The files are located in the directory codem1nw:
dblbnd.adf
hdr.adf
log
prj.adf
sta.adf
w001001.adf
w001001x.adf
# w001001.adf (around 360 MB) contains the main data.
# Info from codem1nw/prj.adf (maybe not necessary):
Projection UTM
Zone 13
Datum NAD27
Zunits NO
Units METERS
Spheroid CLARKE1866
Xshift 0.0000000000
Yshift 0.0000000000
Parameters
# My default region:
GRASS 5.0.2 > g.region -pd
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4480020
south: 4380000
west: 235000
east: 340000
nsres: 30
ewres: 30
rows: 3334
cols: 3500
# gdalinfo:
GRASS 5.0.2 > gdalinfo --version
GDAL 1.1.9.0, released 2003/06/27
# Libraries:
ls -la /usr/local/lib:
-rwxr-xr-x 1 christof admin 3902472 23 Jan 09:33 libgdal.1.1.9.dylib
-rwxr-xr-x 1 christof admin 1363420 1 Jun 2001 libgdal.1.1.dylib
# Import of raster map:
r.in.gdal -o in=codem1nw out=codem1nw.r
r.support -r codem1nw.r
# There were no error messages during the import.
# Info from gdalinfo:
GRASS 5.0.2 > gdalinfo codem1nw
Driver: AIG/Arc/Info Binary Grid
Size is 10418, 8949
Coordinate System is:
PROJCS["UTM Zone 13, Northern Hemisphere",
GEOGCS["NAD27",
DATUM["North_American_Datum_1927",
SPHEROID["Clarke 1866",6378206.4,294.978698213898,
AUTHORITY["EPSG","7008"]],
TOWGS84[-3,142,183,0,0,0,0],
AUTHORITY["EPSG","6267"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4267"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-105],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["METERS",1]]
Origin = (131904.828978,4561132.087882)
Pixel Size = (27.27543571,-27.27543571)
Corner Coordinates:
Upper Left ( 131904.829, 4561132.088)
Lower Left ( 131904.829, 4317044.214)
Upper Right ( 416060.318, 4561132.088)
Lower Right ( 416060.318, 4317044.214)
Center ( 273982.574, 4439088.151)
Band 1 Block=256x4 Type=Float32, ColorInterp=Undefined
Min=1280.949 Max=4412.362
NoData Value=-3.40282e+38
# Note the size (10418, 8949)
# Info from the imported raster map:
GRASS 5.0.2 > r.info codem1nw.r
| Layer: codem1nw.r Date: Tue Feb 17 19:20:36 2004 |
| Mapset: data1 Login of Creator: christof |
| DataBase: /Volumes/FatBoy2/Users/christof/Work/Postdoc/Grass_data |
| Title: ( codem1nw.r ) |
| Type of Map: raster Number of Categories: 4412 |
| Data Type: FCELL |
| Rows: 8948 |
| Columns: 10417 |
| Total Cells: 93211316 |
| Projection: UTM (zone 13) |
| N: 4561145.72559973 S: 4317085.1268369 Res: 27.27543571 |
| E: 416019.40508569 W: 131891.19125998 Res: 27.27543571 |
| Range of data: min = 0.000000 max = 4412.000000 |
| Data Source: |
| Data Description: |
| generated by r.in.gdal |
# Note the size (10417, 8948)
Using r.in.gdal -e ... or r.in.gdal ... location=newlocation did not change anything.
This bug was submitted by Christof Bigler (Boulder, Colorado). If you need more information send
me an e-mail.
See also:
http://www.ecosconsult.com.br/grass-list/arq/11524.html
http://www.ecosconsult.com.br/grass-list/arq/11539.html
http://www.ecosconsult.com.br/grass-list/arq/11556.html
Christof
