this bug's URL: http://intevation.de/rt/webrt?serial_num=2349
Request number 2349 was commented on by 'hbowman' (Harmisch Bowman).
Responding to this message will send mail to the requestor.
Request Tracker
rt@intevation.de
Cc: grass5@grass.itc.it
Are you sure that the map is contained in the current region?
ie run 'g.region rast=erode.index' first.
If there is no data to display, NULL (aka very large integer) is passed to the
range-finding routines & it crashes.
It isn't as simple as testing for data at startup, as if you add a second
raster or set a color layer with no data it will crash out as well, which can
be a pain if you've spent some time getting the view right, etc.
Could that be it?? Is there a MASK in place?
Hamish
