[GRASS5] [bug #2354] (grass) glibc _2.3 not found
this bug's URL: http://intevation.de/rt/webrt?serial_num=2354
Subject: glibc _2.3 not found
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0
Please enter error description here (and your name)
Buen dia, mi nombre es Isaias soy de mexico.
El problema es elsiguiente:
instale el grass5_i686-pc-linux-gnu_bin.tar.gz y el correspondiente .sh para la instalacion; realizo todos los pasos de instalacion hata aqui:
Installation:
1. get the large (32 mb) file
     grass5.0.X_linuxbin.tar.gz
   which is the whole binary in a single file.
2. get the installation script
     grass5_i686-pc-linux-gnu_install.sh
Then you only need to type the following after
you downloaded it (example!):
  sh grass5_i686-pc-linux-gnu_install.sh grass5.0.0_linuxbin.tar.gz [dest_dir] [bin_dir]
This will create the necessary directories and
files for you to run GRASS. The default install path is
/usr/local/grass5/
To install in a different directory, specify it in the
command line:
Usage:
  sh grass5_i686-pc-linux-gnu_install.sh grass_binpackage.tar.gz [dest_dir] [bin_dir]
      with:
        grass_binpackage : name of GRASS 5 binary package
        [dest_dir] - optional: FULL path name to the installation directory
                     (default: /usr/local/grass5/)
        [bin_dir] - optional: FULL path name to the grass binary directory
                     (default: /usr/local/bin/)
                     Notes: 1) Only the grass executable file is stored here
                            2) If you want to change the binary directory only
                               then you need to specify the destination
                               directory as well
You may need login as root for installation.
Example (changing the destdir, keeping the bindir):
  sh grass5_i686-pc-linux-gnu_install.sh grass5.0.0_linuxbin.tar.gz /opt/grass5
After installation start GRASS with
   grass5"
y es en este momento en que me marca lo siguinete:
"Starting GRASS...
/usr/local/grass5/etc/set_data:/lib/i686/libc.so.6:`GLIBC_2.3ยด not found(required by /usr/local/grass5/etc/set_data)
[root@server_lix grass5]# ERROR:LOCATION <</usr/local/grass5/<<UNKNOWN> >> not available"
Utilizo red hat 7.2
Que puedo hacer?, Cual es el problema?.
Agradeceria mucho su apoyo.
Isaias.
