[GRASS5] [bug #2382] (grass) nviz problem
this bug's URL: http://intevation.de/rt/webrt?serial_num=2382
Subject: nviz problem
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.0.3
This error message come when i'm open my raster file and when open vektor file,the picture is not display.
Loading Data
Update elev null mask
Loading Data
translating colors
Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
Xlib: extension "XFree86-DRI" missing on display ":0.0".
info widget made
panel area made
file menu made
Help menu made
disabled made
Nv_mkPanelMenu 1
child killed: segmentation violation
    while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/usr/local/grass5/bin/nviz" line 16)
(iksandi)
Loading Data
Loading Data
translating colors
Nv_(panels)
toplevel made
Probably the X Server configuration in
/etc/X11/XF86Config
is missing the following section:
Section "DRI"
        Group 0
        Mode 0666
EndSection
