this bug's URL: http://intevation.de/rt/webrt?serial_num=2389
Subject: cannot find -lgdal.1.2.0
Platform: Solaris2.X/Sparc
grass obtained from: CVS
GRASS Version: 53_cvs_4_22_04
I updated my sources from CVS today and now when I try to make the binaries it chokes in r.in.gdal:
/export/home/gwurman/Codes/grass53/src/raster/r.in.gdal
mkdir OBJ.sparc-sun-solaris2.8
make -f OBJ.sparc-sun-solaris2.8/make.rules
make[1]: Entering directory `/export/home/gwurman/Codes/grass53/src/raster/r.in.gdal'
gcc -I/export/home/gwurman/Codes/grass53/src/include -w -g -Wall -I/export/home/gwurman/include -DUSE_GDAL_H -c main.c -o OBJ.sparc-sun-solaris2.8/main.o
gcc -I/export/home/gwurman/Codes/grass53/src/include -w -g -Wall -I/export/home/gwurman/include -DUSE_GDAL_H -c gbgetsymbol.c -o OBJ.sparc-sun-solaris2.8/gbgetsymbol.o
gcc -I/export/home/gwurman/Codes/grass53/src/include -w -g -Wall -I/export/home/gwurman/include -DUSE_GDAL_H -c gdalbridge.c -o OBJ.sparc-sun-solaris2.8/gdalbridge.o
gcc -L/export/home/gwurman/Codes/grass53/src/libes/LIB.sparc-sun-solaris2.8 -o /export/home/gwurman/Codes/grass53/dist.sparc-sun-solaris2.8/etc/bin/cmd/r.in.gdal OBJ.sparc-sun-solaris2.8/main.o OBJ.sparc-sun-solaris2.8/gbgetsymbol.o OBJ.sparc-sun-solaris2.8/gdalbridge.o \
-L/export/home/gwurman/lib -lgdal.1.2.0 -lgproj -lgis -lsocket -lI -lgmath -lm -lnsl -lz
/usr/local/sparc-sun-solaris2.8/bin/ld: cannot find -lgdal.1.2.0
collect2: ld returned 1 exit status
make[1]: *** [/export/home/gwurman/Codes/grass53/dist.sparc-sun-solaris2.8/etc/bin/cmd/r.in.gdal] Error 1
make[1]: Leaving directory `/export/home/gwurman/Codes/grass53/src/raster/r.in.gdal'
GISGEN failure at STEP: src/raster/r.in.gdal
This is not fatal when compiling grass53, but the same error also comes up when trying to compile grass57 (in lib/proj/) and there it is fatal. I have absolutely no idea what to do with libraries. Can anyone help?
Gilead Wurman
ASU Active Tectonics
