Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: 5.3-cvs 20040502
I just compiled 5.3-cvs from yesterday and I couldn't convince configure to find the freetype includes. The include path was set
--with-freetype-includes=/usr/include/freetype2
The error message is
checking whether to use FreeType... yes
checking for location of FreeType includes... /usr/include/freetype2
checking for freetype/freetype.h... no
configure: error: *** Unable to locate FreeType includes.
Development files of freetype are installed and "/usr/include/freetype2/freetype/freetype.h" exists.
My system is a debian/sid snapshot from february and freetype is 2.1.7-2.deb
p.s. shouldn't be in the bug report section "Type of report:" 5.3 as well?
Rainer
Check the config.log file for any relevant error messages.
If the error is the following:
/usr/include/freetype2/freetype/freetype.h:20:2: #error "`ft2build.h' hasn't been included yet!"
/usr/include/freetype2/freetype/freetype.h:21:2: #error "Please always use macros to include FreeType header files."
/usr/include/freetype2/freetype/freetype.h:22:2: #error "Example:"
/usr/include/freetype2/freetype/freetype.h:23:2: #error " #include <ft2build.h>"
/usr/include/freetype2/freetype/freetype.h:24:2: #error " #include FT_FREETYPE_H"
then you will need to use a different (older) version of FreeType, or
modify the FreeType headers yourself.
In their wisdom (or lack thereof), the FreeType developers have
decided to insist on the use a specific idiom for the use of FreeType
headers; one which doesn't work with autoconf's header checks.
> Subject: Freetype includes not found
yet!"/usr/include/freetype2/freetype/freetype.h:21:2: #error "Please
files."/usr/include/freetype2/freetype/freetype.h:22:2: #error
"Example:"/usr/include/freetype2/freetype/freetype.h:23:2: #error " #include <ft2build.h>"
FT_FREETYPE_H"
>2.1.7-2.deb
Yes, on Debian[testing/unstable] you need to either modify the #include statements in src/display/d.text.freetype/main.c as outlined
in above error, and then run gmake53 & gmakelinks53 by hand in the
d.text.freetype source directory.
As this is apparently the way of the future for freetype, perhaps
someone can think of a better solution within the build system/main.c
for the long term. We're probably not alone in hitting this...
checking whether to use FreeType... yes checking for location of
FreeType includes... /usr/include/freetype2 checking for
freetype/freetype.h... no configure: error: *** Unable to locate
FreeType includes.
<ft2build.h>" /usr/include/freetype2/freetype/freetype.h:24:2: #error " #include FT_FREETYPE_H"
or modify the FreeType headers yourself.
Thats it. It's not important for me at the moment, so I don't fiddle
about with older versions.
