[GRASS5] [bug #2424] (grass) creating new location with grass57
Are you perhaps trying to do this using a Mac OSX system? This has happened under OSX for a long time and no one seems to know why. The tcltk entry screen is supposed to take you to a text screen to create the new location, but it didn't. The alternative is to start grass in text mode (>grass57 -text) when you want to make a new location.
However, I just downloaded and installed Lorenzo Moretti's new binaries from 15 May 2004 and the new location button finally seems to work properly on my Mac. I will have to try this out more.
Michael Barton
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
On May 24, 2004, at 3:01 AM, grass5-request@grass.itc.it wrote:
Date: May 24, 2004 1:55:34 AM MST
To: grass5@grass.itc.it
Cc: Subject: [GRASS5] [bug #2424] (grass) creating new location with grass57
Reply-To: Request Tracker <grass-bugs@intevation.de>
this bug's URL: http://intevation.de/rt/webrt?serial_num=2424
when creating a new location with grass 5.7 (i installed precompiled binaries
10.5.04) no location is created. the following is displayd in the command
window when button 'create location from epsg' :
g.proj: relocation error: /usr/local/grass57-10_05_2004/lib/libgrass_gproj.so:
undefined symbol: OSRMorphFromESRI
when i select button 'create new location' i get the following:
GRASS 5.7.-cvs:~/diss/grassdata > Error in startup script: ERROR:
LOCATION_NAME not set
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass57-10_05_2004/etc/dm/d.m.tcl" line 786)
after this message i have to repair my .grass57-file.
thanks, sabine
