[GRASS5] [bug #243] (grass) i.ortho.photo: second control point set, but not displayed
this bug's URL: http://intevation.de/rt/webrt?serial_num=243
Subject: i.ortho.photo: second control point set, but not displayed
i.ortho.photo
- if second control point is set by mouse, it is not indicated
   immediately in orange color (right window) [was o.k. in GRASS 4.x]
- GIS WARNING: Can't write embedded null values for map open for random
   access: i.ortho.photo/photo.rectify/write.c needs to be updated.
   (bug still there? 4/2001)
subject 'unsubscribe grass5'
i.ortho.photo
Which bit? i.ortho.photo is just a menu for the various photo.*
programs.
> i.ortho.photo
programs.
Sorry. It appears in
7. Compute ortho-rectification parameters
you have the unrectified aerial image to the left and the raster
reference to the right. When clicking a ground control point (GCP)
in the left, you get a small colored circle in place, when clicking
into the reference image to the right, this small colored circle
doesn't appear (immediately). In i.points that's o.k.
It appears *after* accepting the button (left mouse button), however,
it should appear immediately with orange color and change to green
if accepted with left mouse button.
Hope this clarifies the problem,
> > i.ortho.photo
> programs.
I've added an R_stabilize() call in what appears to be the appropriate
place; can you check that this fixes the problem?
BTW: I did post a reply via the RT, but I haven't seen it appear on
the list.
> > > i.ortho.photo
> > programs.
Glynn,
I have tested, there is no difference. It was never working in GRASS 5
so I assume it's another bug.
The right image dot (second ground control point) should be displayed
before
Look ok? (Left: y / Right: n)
appears. But it is displayed only *after* right mouse button to accept.
In i.point that is o.k., but there is not the convenient mouse answer method
as implemented in i.ortho.photo at this point. Maybe i.point and the
i.ortho.photo subroutine could be compared (I tried, but didn't find the
bug).
the list.
This was switched of yesterday as requested by the RT manager.
Regards
