this bug's URL: http://intevation.de/rt/webrt?serial_num=244
Subject: d.rast.num: some numbers are displayed in wrong (unreadable) color
subject 'unsubscribe grass5'
Can anyone confirm that this is a real bug? Or does it come from not
using d.rast first? (AFAICT, d.rast.num draws the text in either black
or white, depending upon whether the cell is light or dark
respectively).
In any case, there should probably be an option to set the text
colour, so that d.rast doesn't have to be used first.
