this bug's URL: http://intevation.de/rt/webrt?serial_num=247
Subject: nviz2.2: the parameter el= is inconsistent
the parameter el= is inconsistent (e= should be allowed as well),
parameter order should be free (use a "case" switch?)
subject 'unsubscribe grass5'
