[GRASS5] [bug #249] (grass) r.rescale: -z flag wanted
this bug's URL: http://intevation.de/rt/webrt?serial_num=249
Subject: r.rescale: -z flag wanted
  r.rescale input=asp1 from=0,180 output=test_north to=1,1
  r.rescale does not set cells outside the "from" range to 0 (described in the
  help), but to NULL
  (reported by timcera@earthlink.net)
Andreas Lange, 10/2000: This is IMHO not a bug, but a feature. All modules
  should write NULL instead of 0 (zero) for missing values for patching
  maps or display overlays.
  But if the problem with r.reclass is solved i can add a "-z" flag that
  switches this behaviour from writing NULL to writing "0" (zero).
  (being worked on by Andreas Lange)
subject 'unsubscribe grass5'
