[GRASS5] [bug #2500] (grass) compiling grass-5.7.0 - unable to locate lex
this bug's URL: http://intevation.de/rt/webrt?serial_num=2500
hello
i would like to compile the new version of grass-5.7.0 but the first problem
rises with ./configure.
ueberflieger:/usr/local/grass-5.7.0 # CFLAGS="-g -Wall" ./configure
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -g -Wall ) works... yes
checking whether the C compiler (gcc -g -Wall ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /usr/local/grass-5.7.0
checking for build directory... /usr/local/grass-5.7.0
checking how to build libraries... shared
yes
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking if 64bit support is requested... no
checking if 64bit Sparc VIS support is requested... no
checking system version (for dynamic loading)... Linux-2.4.21-166-default
checking for dlopen in -ldl... yes
checking for ar... ar
checking for SysV... no
checking for another button... no
checking for XDriver... socket
checking for additional include dirs...
checking for additional library dirs...
checking for a BSD compatible install... /usr/bin/install -c
checking for flex... lex
checking for yywrap in -ll... no
checking for lex... no
configure: error: *** Unable to locate lex.
how to continue?
thanx, sabine
--- Headers Follow ---
From csab7771@uibk.ac.at Tue Jun 22 15:27:24 2004
Return-Path: <csab7771@uibk.ac.at>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 776BA13954
  for <grass-bugs@lists.intevation.de>; Tue, 22 Jun 2004 15:27:24 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
  by mail.intevation.de (Postfix) with ESMTP id 995EB36E1E
  for <grass-bugs@lists.intevation.de>; Tue, 22 Jun 2004 15:27:21 +0200 (CEST)
Received: from smtp.uibk.ac.at (lmr1.uibk.ac.at [138.232.1.142])
  by mail.intevation.de (Postfix) with ESMTP id E7CE136E1B
  for <grass-bugs@intevation.de>; Tue, 22 Jun 2004 15:27:20 +0200 (CEST)
Received: from localhost (lwm2.uibk.ac.at [138.232.1.161])
  by smtp.uibk.ac.at (8.12.10/8.12.10/F1) with ESMTP id i5MDRGvD013484;
  Tue, 22 Jun 2004 15:27:17 +0200
Received: from pc94-c707.uibk.ac.at (pc94-c707.uibk.ac.at [138.232.34.94])
  by web-mail2.uibk.ac.at (IMP) with HTTP
  for <csab7771@mail2.uibk.ac.at>; Tue, 22 Jun 2004 15:27:16 +0200
Message-ID: <1087910836.40d833b4e4852@web-mail2.uibk.ac.at>
Date: Tue, 22 Jun 2004 15:27:16 +0200
To: GRASS <grasslist@baylor.edu>
Cc: grass-bugs@intevation.de
Subject: compiling grass-5.7.0 - unable to locate lex
MIME-Version: 1.0
Content-Type: text/plain; charset=iso-8859-15
Content-Transfer-Encoding: 8bit
User-Agent: Internet Messaging Program (IMP) 3.2.1
X-Originating-IP: 138.232.34.94
X-Forwarded-For:
X-Spam-Status: No, hits=-3.9 tagged_above=-999.0 required=3.0 tests=BAYES_00,
  FROM_ENDS_IN_NUMS
X-Spam-Level:
