[GRASS5] [bug #2507] (grass) v.digit: implement an elastic band function
this bug's URL: http://intevation.de/rt/webrt?serial_num=2507
Subject: v.digit: implement an elastic band function
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: GRASS 5.7 CVS 20040625
For the new v.digit in GRASS 5.7 I would like to see an elastic band function as it is implemented in the old v.digit in GRASS 5.0/5.3.
Digitizing long lines e.g. contour lines you always need to stop digitizing, then set a node, then use the pan function and start digitizing from the node again. For this an elastic band as in the old v.digit would be very helpful.
thanks
  Otto
