[GRASS5] [bug #251] (grass) r.stats: some inconsistent results comparing to r.average
this bug's URL: http://intevation.de/rt/webrt?serial_num=251
Subject: r.stats: some inconsistent results comparing to r.average
*First, I compute the per-class averages:
     r.average base=medv cover=test out=borra.me
*Second, I check the result for, i.e., class 23:
     d.what.rast map=medv,borra.me
     2676500(E) 4409500(N)
           medv in user1 (23)S_SUPRAMEDITERRANEAN_ZONE
           borra.me in user1, quant (111)
           borra.me in user1, actual (110.794075)
*Third, I compute the statistics for each class, but the results are not
  the same as given by d.what.rast. For example, for class 23:
     r.stats -c in=medv,borra.me
     r.stats: 100%
       23 110.299171-110.744906 6082
*While d.what.rast was giving 110.794075. Is this a bug?
     Dr. Agustin Lobo, alobo@ija.csic.es
subject 'unsubscribe grass5'
