this bug's URL: http://intevation.de/rt/webrt?serial_num=2526
Subject: compiling with readline
Hallo!
I had a little problem when compiling GRASS with readline on fedora 2: Linking
readline fails when ncurses is not linked as well. I adapted the configure
script accordingly such as the configure and make process are ending correctly.
The patch above shows the necessary changes.
Many greetings,
Silke
--- configure.orig 2004-06-17 15:26:22.000000000 +0200
+++ configure 2004-07-01 17:02:03.119838488 +0200
@@ -8085,7 +8085,7 @@
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
-LIBS="-lreadline $LIBS"
+LIBS="-lreadline -lncurses $LIBS"
cat > conftest.$ac_ext <<EOF
#line 8091 "configure"
#include "confdefs.h"
@@ -8112,7 +8112,7 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
- READLINELIB="$READLINELIB -lreadline "
+ READLINELIB="$READLINELIB -lreadline -lncurses "
else
echo "$ac_t""no" 1>&6
