this bug's URL: http://intevation.de/rt/webrt?serial_num=253
Subject: r.watershed: needs to be *partly* updated to GRASS 5 FP/NULL
Helena Mitasova wrote:
Drainage map should be INT, there is no reason for it to be FP
because the program uses D8 algorithm, there are only 8 directions
of flow. only L and S factor could be output as FP (here they are
multiplied by 100) but I am not sure whether it is worth the effort
because they are not very good anyway.
subject 'unsubscribe grass5'
