[GRASS5] [bug #2594] (grass) MASK and Mapset conflicts
this bug's URL: http://intevation.de/rt/webrt?serial_num=2594
Subject: MASK and Mapset conflicts
Platform: GNU/Linux/i386
grass obtained from: CVS
Dear list,
When I start GRASS and select several other mapsets with g.mapsets and one of
them already includes a MASK file, then it isn't possible to create another
MASK file in the current mapset anymore, although the MASK is not in that
mapset.
ERROR: <MASK> already exists in mapset <norden_p8>
When I deselect the other mapsets, then I am able to create a MASK again.
Can this be solved somehow?
thanks in advance
  Otto
mapset.
That particular behaviour is part of g.copy and g.rename; you can use
the -o flag to override it.
These programs don't distinguish between the case where the
destination exists in the current mapset and the case where it exists
in some other mapset. You have to use -o if the destination name is in
use in any active mapset.
I believe that this behaviour is intentional, to prevent the user from
inadvertantly "shadowing" an existing map.
If you aren't using g.copy/g.rename directly, but are using some other
program which calls them, tell us which one; we may wish to add the -o
switch.
Note that the raster I/O code only looks for the MASK file in the
current mapset; a MASK file in other mapsets won't be used as a mask.
On Thu, 26 Aug 2004 20:26:04 +0100
> mapset.
switch.
No, I use g.copy and g.rename
In this case, the -o flag is a good solution.
  Thanks
   Otto
