this bug's URL: http://intevation.de/rt/webrt?serial_num=264
Subject: v.digit: Initial map scale should be 1:1 (not 1:0)
v.digit: when creating a new map, the initial map scale should be at least
1:1 (not 1:0) as 1:0 will cause many problems with snapping etc.
src/mapdev/v.digit
head_info.c: queries the map scale, it is defined in "orig_scale"
However, I am not sure where to change this. It seems to be defined in
vect32 library.
subject 'unsubscribe grass5'
