this bug's URL: http://intevation.de/rt/webrt?serial_num=2664
Subject: r.contour writes negative elevations to category
Platform: Mac OSX
grass obtained from: Trento Italy site
GRASS Version: 5.7cvs20041009
r.contour puts the contour elevations in the category. A minor drawback is that this rounds any
fractional elevation values to integers, so is useless for fine detail contouring. The big problem is
that it will write negative categories, which I'm told is wrong.
r.contour should write elevations to a table. It does put the elevations in the z (height) of the
vector, but there doesn't seem to be a height option to v.to.db (just length and area). That would be
the other solution - maybe easier to do.
Platform: Mac OSX
that this rounds any fractional elevation values to integers, so is useless
for fine detail contouring. The big problem is that it will write negative
in the z (height) of the vector, but there doesn't seem to be a height
option to v.to.db (just length and area). That would be the other solution
Now it writes a table with levels.
WARNING: cats are not level values any more!
Radim
Cool. But, slight problem - the cat values used in the vectors ranges from 1..n, while the cat values used in the table range from 0..n-1 (n being the number of unique levels from r.contour). So all the contours get shifted up 1 level, and the upper contours have no db record.
Platform: Mac OSX
Radim
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
William Kyngesburye <kyngchaos@charter.net>
http://webpages.charter.net/kyngchaos/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
Thanks. Fixed.
Radim
