[GRASS5] [bug #2686] (grass) Problem with v.category
this bug's URL: http://intevation.de/rt/webrt?serial_num=2686
Subject: Problem with v.category
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: grass5.7.cvs-i686-pc-linux-gnu-23_10_200
I need to change the category value of several areas in order to query a DB, and v.category is not working fine.
- I'm running version grass5.7.cvs-i686-pc-linux-gnu-23_10_2004, and I need to change de category value of an area.
If I run this
v.category input="vec_area_3" output="vec_Area_34" type="boundary,centroid,area" option="add" cat=4 field=1 step=1
only the value of boundary change, the value of Area is still 1
If I run this
v.category input="vec_area_3" output="vec_Area_34" type="area" option="add" cat=4 field=1 step=1
the value of area is still 1, nothing change
- I changed the version to grass5.7.cvs-i686-pc-linux-gnu-06_11_2004
and if i run
the vector vac_area_34 is not createad, nothing happen.
Ignacio
