this bug's URL: http://intevation.de/rt/webrt?serial_num=269
Subject: Grass5 and NFS
Platform: Linux/Intel
Linux distro: RedHat
linux cpu: AMD (K6, ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: wmaker
grass binary for platform: I compiled the sources myself
grass sources source: no, I got a source code package from the server, 5beta1
c compiler name: gcc
at the command d.mon start=x0 it asnwers that it can't complite the locking procedure.
Indeed the dir for locking is exported by nfs and it doesn't have the permision to write on it.
So maybe there is a env-variable to change in order to make grass lock at a dir with write permision.
chmod -R 1777 /usr/local/grass5/locks/
just done but nothin change.
Arjuna
subject 'unsubscribe grass5'
